speedo recalibrator on a 00? - FirebirdV6.com/CamaroV6.com Message Board
  • speedo recalibrator on a 00?
    What options do I have for a speedo recalibrator on a 00 3.8L?
    the speedo is controlled from within the stock computer. all you have to do is get it reprogrammed for the new gears set. most shops that have taps to read obd2 can take care of this for you in a few mins.
    later
    tim
    NJ SPEEDER<br />1976 Camaro LT<br />Crate 350, TH350, 3.90 posi<br />New Jersey F-Body Owners Association<br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
      you can get the speedo recalibrator from SLP, i think it retails for $170 USD...and i *think* it's intense racing that sells a recalibrator for $100 USD.
      both of them just get spliced in between the pcm & speedometer. there are little switches on them that you have to setup for your application. they manipulate the signal coming from the pcm to fit your application.
      --matt
        <blockquote>quote:</font><hr>Originally posted by njspder:
        later
        tim
        <hr></blockquote>
        No...very few shops can reprogram our comps. The ones that can charge $300 to do it.
          <blockquote>quote:</font><hr>Originally posted by speedy-v6-camaro:
          <hr></blockquote>
          exactly...
          what about HPP3?
            <blockquote>quote:</font><hr>Originally posted by MustangEater8251:
            exactly...
            what about HPP3?
            <hr></blockquote>
            my friends dad has a hand held from snap-on that can do it. it is included in the diagnostic software to adjust certain points in the programming. the same is true of many other brands hand helds for ODB2, they are great toys if you can afford them.
            later
            tim
              I got the recalibrator from intense, works fine.
              <b><a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six©</b></a><br /><a href=\"http://www.sounddomain.com/id/95batmobile\" target=\"_blank\">My \'95 Bird</a><br />I am not afraid of storms, for I am learning how to sail my ship.
                how much do dealers usually charge to flash a PCM with a y87 vin #??? Shouldn't be that expensive...someone once mentioned it only costed them like 30 bucks i think. Anyone have it done and know the cost to have a dealer do it?
                http://www.bowtiev6.com/
                  how hard is it to change the settings with the speedo recalibrator anyways... also is there a 4.10 option :D
                    how hard is it to change the settings with the speedo recalibrator anyways... also is there a 4.10 option :D <hr></blockquote>
                    Not that hard at all...and yes, you can program for 4.10
                    94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
                      <blockquote>quote:</font><hr>Originally posted by Camaro_SLP:
                      <hr></blockquote>
                      yup, you can definitly do it with the SLP one. [img]graemlins/thumbsup.gif[/img]
                      --matt
