has anyone used this on their car ,if so how did it come out. i just recieved mine and was wondering if the install was easy. thanks
mini speedometer recalibrator
96' Camaro M5 to A4 conversion, alot of mods . GT35R Turbo full suspension. Built engineTags: None
if ur talkin about the SLP one it did exactly what i wanted it to do in my car, correct the speedometer....
BTW...you own a camAro and cant even spell camAro?? fix ur sig man! [img]smile.gif[/img]<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
its the one from intense racing, thanks for the spell check.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
i installed the techedge mini-speedometer recalibrator from intense racing and it is working out great.Just thought i would let you people know in case someone was looking to adjust their speedometer and it was only about $100. Also it was very simple to install.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
it will correct the speedo if you added 3.73s but i don't know about shift points, mine is a 5 speed. For the install it was just splicing the #13 wire on the pcm for the speed signal and a ground wire and a ign. wire for power. Took maybe 30 minutes if that.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
