I have always wondered what the diffrence between OEM(zexel) Auburn and Eaton posi units or LSD's Why does the OEM one cost 200-300 dollars less than one another?
Diffrence Between OEM and Eaton, Auburn
The torsen doesn't actually cost so much less... retail cost for the torsen OEM unit from GM is $822.83.
GM PART # 12363985
CATEGORY: All
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $822.83
OUR PRICE: $575.98
DESCRIPTION: DIFF Z-T
The thing is, its dirt cheap from SLP because they're selling it as a take-off unit. Even wholesale on it is still $575!
The Torsen unit doesn't use clutches, it uses a worm gear drive system. The Eaton uses a flat disc clutching system, while the auburn uses a cone shaped clutching system (more surface area). The T2-R is a worm gear torsen with clutch packs to help it bind even more, and its sold by sam strano for roadracing [img]smile.gif[/img]
Checkout my differential guide if you need to, its on my homepage.2002 5-spd NBM Camaro
Details: www.1lev6.com
<blockquote>quote:</font><hr>Originally posted by Dominic:
Checkout my differential guide if you need to, its on my homepage.[/QB]<hr></blockquote>
Great summary Dominic, thanks!! Been searching for something like that. Opinions are great and welcome, but sometimes simple reading works wonders
<blockquote>quote:</font><hr>Originally posted by naptown:
So since the Torsen "take-off" is only 99$ should I go ahead and buy it? Also will it bolt directly onto my M5?<hr></blockquote>
Yes, I certainly did.2002 5-spd NBM Camaro
Dominic, if I'm understanding correctly what your guide says, I'm gonna need to get a new differential or get it rebuilt after 40,000 miles??? Damn, that is not worth the money I paid for that differential!!!
EDIT: Oh, I just remembered, Auburns CAN'T be rebuilt!
[ April 23, 2003: Message edited by: Camarorulz ]</p>-Eric<br />2002 Navy Blue Camaro...Striped and Stalled. 35th Anniversary SS wheels <br />Best ET: 15.384 @ 88.32 on street tires<br />Project Whitney: Goal, 14.0 1/4 by summer 2008.
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...15 hours ago
