need help and possible causes and solutions to a problem ASAP due to warranty - FirebirdV6.com/CamaroV6.com Message Board
  • need help and possible causes and solutions to a problem ASAP due to warranty
    For a while now I've noticed that sometimes, not every time that I reverse whether it's a turning reverse or going straight back reverse, there is a very strange and troublesome noise coming from the front end which I'm unable to pin down. The noise sounds very loud usually and is similar to tearing or grinding of metal pieces or a collision of something with another part of my car.
    When it happens it is constant sound depending on how fast I reverse and it doesn't matter what speed I reverse at it still happens just the degree of noise and the noise level changes. It's just got me worried that something with the trans. is breaking or loose of the flywheel is damaged or something like that. This only happens when I go in reverse and does not always happen. Also I was thinking of possible problem with my suspension or or tires or steering components. Any help would be appreciated and I need to know ASAP just to be on the safe side especially since its driving me nuts not knowing what the noise is and if it's causing damage. Thanks in advance either email me at opt0tolerance@aol.com or post here. Thanks again.
    1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
    When was the last time the trans & rear-diff were serviced?
    2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
      It was serviced less then 6 months ago. A new rear diff. was put in around January or so and then I had it serviced around June/July time. It sounds like its coming from the front end or near the middle of the car. Any ideas? Thanks.
        Any ideas? Anybody?
        • Manimal
          Coil springs
          by Manimal
          6 days ago
        • Manimal
          Newby here
          by Manimal
