Need Answers Before Getting 3.73s - FirebirdV6.com/CamaroV6.com Message Board
  • Need Answers Before Getting 3.73s
    I'm going to end up getting a 3.73 rear-end set-up with an LSD, but I don't know if I will need to take precautionary steps to aid the engine/transmission. Will I need to add anything to the car before the gears? Will I need to recalibrate the speedometer?
    i believe you will have to recalibrate the speedo
    2003 Chrome Silver Nissan 350z 6 Speed<br /><br />2001 Bright Rally Red Camaro 3800 M5-----SOLD but missed
      well... You don't HAVE to... I'd recommend it though...
        the engine/tranny shoudl do fine with 3.73s.
        2002 5-spd NBM Camaro
        Details: www.1lev6.com
          Is there any type of program I could just buy to recalibrate it myself? Maybe even tune it too? It's a '98.
            HPTuners :D
            - Justin
              I heard with 3:73's your first gear is so short it's almost useless. Is that true?
              Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
                you will need to recalibrate the speedometer in order to keep your shift speeds right and also to not hit the speed limiter..unless its a manual..then you'd just want to recalibrate the speedometer..also if you are going from a 2 series differential to a 3 series you will need to get a 3 series ABS reluctor ring in order to keep your ABS operational (if you have ABS)..you can get one from www.slponline.com for about $20
                  jessica-
                  I will let you know in a few hours, my gears are getting installed as we speak.
                  1995 Camaro 3.4L Black with T tops, 5 speed manual<br /><br />Mods:<br />Pro 5.0 short throw shifter, MSD Ignition coils, 3.73 gears, Torsen LSD,Mac diff cover, Umi LCAs<br />K&N Cold Air Intake, Window Tint (20% rear, 35%front), aluminum driveshaft, fastchip tuning
                    LittleG has 4.10's with the M5 (3.75:1 first gear) and at full throttle, first is good for just over 60' [img]smile.gif[/img]
                    - Justin
                      remember to let em break in a lil bit before you floor it.
                      97 RS<br />Member Status: F-Body Owner<br />Member Number: 7705<br />Registered: September 13, 2005<br />Posts: 24<br />Email Address: hfoxx123@yahoo.com<br />Location: Minnesota<br />Occupation: Database Administration<br />Homepage: <a href=\"http://none\" target=\"_blank\">http://none</a><br />Car: uh a camaro
                        Not true.. 3.73's are the $hit.. Still got 32mpg on the highway with my stock motor..
                        Jeff ..
                        1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
                        2002 WS6 T/A.. Bolt ins..448rwhp
                        2009 G8 GT.. Vararam intake, GXP axleback
                        1998 Corvette.. Vararam intake, Ti axleback
                        http://www.fquick.com/slow-v6
                          One more question... what all am I buying?
                          LSD
                          3.73 gears
                          Ring spacer
                          Cover
                          Do I need an install kit or anything else?
                            gear install kit i think
                              if i granny it, i'm shifting at about 20 mph with my 5 speed. So to answer your question, yes i still use first gear.
                              For the full install you will need
                              gears
                              lsd
                              cover
                              install kit
                              gear lube
                              limited slip addative (if needed)
                              and the reluctor ring
