Replace Driveshaft to 1LE While Swapping the Rear End? - FirebirdV6.com/CamaroV6.com Message Board
  • Replace Driveshaft to 1LE While Swapping the Rear End?
    I will be swapping out rear ends in my car in two weeks and figure since it's all out I should maybe pick up a 1LE driveshaft. Any thoughts on this? Ever says it is a great mod, but what makes it so great compared to the stock one I have?
    Thanks
    2000 Z28 M-6<br />Loudmouth, TSP Lid, MAF Ends<br />330 rwhp
    Another quick question...
    On the LS1 cars they use the aluminum driveshaft? Is it the 1LE? What's the difference between the two?
      there's this thread. and stock most Z28/SS cars come with a steel one piece unit, while the 1LE optioned cares come with a package of 1LE which includes the aluminum drive shaft.
      Silver \'98 Camaro M5<br />Current MODs:<br />SLP strut tower brace; SLP 1LE swaybars front/back; Powerslot rotors; Hawk pads; Eibach springs; Bilstein SLP shock kit; SLP trans mount; Zexel limited-slip differential; LS1 drive shaft.<br />Possible future MODs:<br />BMR Lower Control Arms; BMR Pandhard Rod.
        LS1 powered cars come with aluminum driveshafts. Just get on off that.
        <b>99\' Black Camaro SS</b> <br />M6/T-Tops - SLPLid w/K&N | Hurst Billet Plus w/ LSS | EGR Mod<p>Black 97\' Camaro T-Tops (RIP)
          <blockquote>quote:</font><hr>Originally posted by Spray'dV6:
          <hr></blockquote>
          The LS1 driveshaft is not a 1LE driveshaft. The LS1 driveshaft is 3" in diameter while the 1LE is 2.75" in diameter.
          Has the issue of clearance between 3" LS1 driveshafts and 3" exhaust ever been put to rest? I remember some said it would conflict and others have said it would not.
            http://www.lingenfelter.com/lingenfe...50&pf%5Fid=217
            Raven
              I guess since there is a 3.5" driveshaft for LS1's which would probably also have at least a 3" exhaust on it there aren't any clearance issues.
