Does anyone know of any instructions to look at on the net for installing one so I can read up to see if I wanna do this or pay someone to do it for me
Master Cylinder Install
a clutch master cylinder? i had to replace that in mine.or isnt that what your talking about?1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
hm, well it took me and my dad about 2 hours, but we had a hard time. its half inside the car and half outside. it goes though the fire wall.do you have intructions? some tips real quick, you NEED two people, put the drivers side seat back all the way , as one person have to lay on their back with their feet on the seat pretty much, at least one flash light for the person inside, and maybe on for the person outside.now as for location, on the inside right above the clutch petal you can see the metal bar type thing with the circle on the end. from the outside, its in a horrible spot, right under the vacume booster for the brakes, theres a U bolt that hold it to the firewall that takes awhile,because you need to have both sides in the same amount other-wise it wont fit.you NEED to bleed the clutch fluid after you change it, i had to 3 times, when doing this dont take the needle all the way out, if you listin closly you can hear the air comeing out of the lines, you NEED two people for that too. as for instuctions, mine came with the part, and i used my manual too. if you have any questions i'll be happy to answer and try to help. or if some of that didnt quite make sence just ask.good luck.
-Pat1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...59 minutes ago
