Alright, I went & got my oil changed today & found out I have 2 leakes. :mad: My transmission is leaking from the top. & my rear end is leaking from where the driveshaft is coming in. Anybody else have any similar problems & have any suggestions???? I was planning a rear-end gear swap w/ a lsd. I guess now is the time. I guess a high performance clutch is in my future as well whenever they drop the tranny to see what is the matter. ahhhh... I hate car problems! anybody have any suggestions????
I have things leaking
<blockquote>quote:</font><hr>Originally posted by kaygee08:
Alright, I went & got my oil changed today & found out I have 2 leakes. :mad: My transmission is leaking from the top. & my rear end is leaking from where the driveshaft is coming in. Anybody else have any similar problems & have any suggestions???? I was planning a rear-end gear swap w/ a lsd. I guess now is the time. I guess a high performance clutch is in my future as well whenever they drop the tranny to see what is the matter. ahhhh... I hate car problems! anybody have any suggestions????<hr></blockquote>
u need a new trans or a rebuild
$2500
start saving
-Steve
Cooler lines enter and exit on the top of the transmission. One of them must need replacing. Don't drive low on transmission fluid or you'll burn it up in minutes.
Pinion seal must be leaking also. It's a cheap part, but alot of labor.
I was under my car the other day and traced a few problems. That little joint type thing before the driveshaft is leaking. And my oil pan on the very top is leaking. I thought it was my transmission because theres oil all over it but it was just splattering. I dunno try to pin point exactly where everything is coming from.
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...7 hours ago
