When I shift into any gear my transmission makes a whinning noise and is very hard to get into gear and sometimes when sitting at a stoplight if I leave it in gear with the clutch pushed in it will start to whine and I have to force it into nuetral even with the clutch pressed in, the fluid is fine and I had a new clutch and slave cylinder installed last year but it is all out of warranty now, Any Ideas
Throw out bearing?
does the noise go away if you apply pressure to the pedal but not press it all the way in? if so then it is your throwout bearing
although, it sounds to me like your synchros are bad1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
Originally posted by blackFbird_98:
When I shift into any gear my transmission makes a whinning noise and is very hard to get into gear and sometimes when sitting at a stoplight if I leave it in gear with the clutch pushed in it will start to whine and I have to force it into nuetral even with the clutch pressed in, the fluid is fine and I had a new clutch and slave cylinder installed last year but it is all out of warranty now, Any IdeasRobert - owner www.FirebirdV6.com/CamaroV6.com
Raven
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
