Has anyone actually installed one of these?
ZZP Speedometer Calibrator
RavenTags: None
No, but I have heard of some of them causing your cruise control to act up, so I thought I would let you know. Let me know what you find out, I just installed a new rear end and mine is off too. I went from 3:08's to 3:42's.Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
Originally posted by 95Batmobile:
Yes.
Do a search.
Which manufacturer do you have? Tech Edge or easy Performance?Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
both he and I have the techedge. I bought mine through zzp. His is installed and mine isn't cuz i'm too lazy. I'm getting fastchip tuning done so i'm probably not going to need my recalibrator untill i put rims and tires on my car. As far as i know he doesn't have any problems with the cruise control. If you wanted, you could get hp tuners and recalibrate your own speedometer, with no need for a chip/recalibrator.1995 Camaro 3.4L Black with T tops, 5 speed manual<br /><br />Mods:<br />Pro 5.0 short throw shifter, MSD Ignition coils, 3.73 gears, Torsen LSD,Mac diff cover, Umi LCAs<br />K&N Cold Air Intake, Window Tint (20% rear, 35%front), aluminum driveshaft, fastchip tuning
Mine works perfect, I cruise home with my cruise control all the time, no problems.
All it does it cut the signal coming from the CPU going to the speedometer.
And xx315, sorry I havn't found that wire for you yet. My brother's blazer blew up on the way home going over the mountains, so I was pulling the motor and trans out with my dad while I was home and doing all the stuff my car needed as well. Let me know if you still need it, my dad bought me a cheep toolkit so I can probably go find which wire it is. You said you're getting fastchip, so that will solve the problem either way. Fastchip is very nice too, one of the best things I ever did to my car.<b><a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six©</b></a><br /><a href=\"http://www.sounddomain.com/id/95batmobile\" target=\"_blank\">My \'95 Bird</a><br />I am not afraid of storms, for I am learning how to sail my ship.
Originally posted by xX315Xx:
both he and I have the techedge. If you wanted, you could get hp tuners and recalibrate your own speedometer, with no need for a chip/recalibrator.
And, there is no PCM programming for a 96.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
DHP works on 96. Or you could easily swap in a 97 PCM and use HP Tuners.Matt
1998 Mystic Teal Camaro M5
Originally posted by 98Camaro3.8:
</font><blockquote>quote:</font><hr />Originally posted by FirebirdGT:
DHP works on 96. Or you could easily swap in a 97 PCM and use HP Tuners. </font>[/QUOTE]I know about the 97 PCM, but last thing I heard the DHP 96 was not available yet.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
I bought mine a few weeks ago from them and it's a techedge. bats- dont sweat it, i get a hold of you when i finally need to install the recalibrator, but i'm going with the fastchips tuning and that should take care of it. I've been too busy to even look at the recalibrator. If i was that ambitious after my long days i could have looked up a pin-out of our pcm's and figured it out, but oh well. Thanks for all of your advice when i was tryin to figure that out. I love the gears btw...1995 Camaro 3.4L Black with T tops, 5 speed manual<br /><br />Mods:<br />Pro 5.0 short throw shifter, MSD Ignition coils, 3.73 gears, Torsen LSD,Mac diff cover, Umi LCAs<br />K&N Cold Air Intake, Window Tint (20% rear, 35%front), aluminum driveshaft, fastchip tuning
