I decided to take my console out today to see if it would be difficult because i would like to install a short throw shifter. And as I suspected, it was a pain in the *** . I would like to install the shifter but my questions are is the shifter a difficult installation, and is there any way I could remove/re-install my console without tearing up my parking brake handle? I tried to remove it, but it looks like there is a rivet holding it in place. Its a '97 Camaro. Any help would be appreciated.
Is it just me?
Piece of cake -- you insert a flatheaded (And long) screwdriver down toward the parking brake's gear mechanism, to trigger a release lever. This lets the handle come up 90* or so, and you can just straight lift the lower console up and out of the car, so that the shifter can be installed. When you're finished, put the console back on, release the handle (either button or screwdriver, I forget), and try it a few times up and down to make sure it's back to normal.
I have a Pro 5.0
-Rob<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
on 97+ consoles, (M5/M6)
remove 2 7mm screws under the coin holder, inside the center console.
Remove shift knob.
Lift up on center section, to remove upper console
remove 1 10mm screw under the upper console.
Clean out all of the crap you have in the center console, so you can get to the 2 10mm screws under there.
Remove the 2 10 mm screws on the front/side of the console, 1 per side.
Do the e-brake thing, with finger, or screwdriver, and lift up.
Slide console out.
remove shifter boot cover, using a 7mm nut driver.
remove shifter, (not sure size on the V6)
reverse to put back together [img]smile.gif[/img]
Ryan. <-- all this was by memory, i've removed a few before...1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...4 days ago
