Is the 2 piece driveshaft on our sixers NOT strong enough for the Ls1? Do I NEED to replace it with the one piece alum. driveshaft?
Driveshaft
The two piece driveshaft is a piece of junk. I have no idea why GM ever put that in a car. It was supposed to transmit less vibration to the passenger compartment than a 1 piece. In my experiance, my 95 Camaro felt much more "wobbly" than my 00 Firebird.
To answer your question, yes, you need to replace the driveshaft. Aluminum would be nice, but a factory 1 piece steel one would work just as well.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
I'm not sure why this is in advancd tech. Moving to drivetrain.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
by Need4CamaroThe panel under the HVAC controls where the button is supposed to be is completely missing when I bought the car so I dont know if this car had TCS or...3 weeks ago
by Need4CamaroI was wondering, are these cars DBC or DBW?
If swapping in an LS motor (lets ignore the rest of the complexity of the swap), what would be...3 weeks ago
