i bought my car used so im not exactly sure about anything. but anyways, i thought i had the Y87 package cause i burn both tires off the line and when doing burn outs. but then i found out that u r suppose to have dual exhaust which i didnt have stock. some one please help. i dont like not knowing whats is going on with my car. :( :(
Y87 performance package?
Tags: None
<blockquote>quote:</font><hr>Originally posted by BLLDOGG:
i bought my car used so im not exactly sure about anything. but anyways, i thought i had the Y87 package cause i burn both tires off the line and when doing burn outs. but then i found out that u r suppose to have dual exhaust which i didnt have stock. some one please help. i dont like not knowing whats is going on with my car. :( :( <hr></blockquote>
i think those are different not sure,
but do you have disk brakes or drum?
LSD plus disk for 97 and under is = Y87www.turbov6camaro.com
1997 3800 Series II Camaro
Or the previous owner put the rear end on the car so that it has 3.42s and lsd. Check your codes on your door for the y87 code.
will it say Y87???
thanks for help guys
o' plus, its a 2000, and i have all 4 disc brakes
and the info i have read said that to have Y87, u r suppsoe to have sld which i think i have, 3.42 gears which im going to have checked today and dual exhaust which i dont. please help
[ February 09, 2004: Message edited by: BLLDOGG ]</p>
Some 2000's didn't come with the Y87 Performance Package. However, they did get the 3.42 gears. Open your driver's door and look for codes GU6 and G80. Mine came from the factory with 3.42's and a single turndown muffler.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
alright, its says gu6 and g80 and what do they mean. but then y do i burn both tires all the time. i have never burned just one.
will it say Y87???
[ February 09, 2004: Message edited by: BLLDOGG ]<hr></blockquote>
that ok my cars VIN says its a RS and its notwww.turbov6camaro.com
alright, its says gu6 and g80 and what do they mean. but then y do i burn both tires all the time. i have never burned just one.<hr></blockquote>
GU6 is 3.42's and G80 is LSD. I think that would make it Y87, but even if it's not, since you've got those and 98+ cars came w/rear discs you've got everything you'd want anyway.
[ February 12, 2004: Message edited by: RevLimit478 ]</p>Psykopig16: well the car will run with a broken crank..<br />RevLimit478: yeah, it\'ll run like a fat kid in summer
