I recently purchased a 96 auto camaro and when I floor the gas pedal the rpms go to 4500 and then shifts to second and then redlines and keeps bouncing in the red without shifting to third any ideas on what it could be
help with my camaro
The first thing to do is to change the fluid and filter, and see how it works then. In the mean time don't beat on it too much.
Sounds like it could be sticky valves, damaged pressure sensors, or damaged wiring.
Anyway, first thing to do is to change the fluid and filter.<a href=\"http://www.fatninjas.com/camaro\" target=\"_blank\">\'96 Camaro Convertible</a>
I'm not sure because I have a manual, but does the auto use any kind of vacuum to help with the shifting? If so This could cause your problem. If not I would think you need a rebuildMy Car: 1994 Camaro 3.4 V6 5-Speed<p><a href=\"http://www.cardomain.com/id/speedyman_2\" target=\"_blank\">My Car</a>
<blockquote>quote:</font><hr>Originally posted by 96_V6_Fbody:
I'm not sure because I have a manual, but does the auto use any kind of vacuum to help with the shifting? If so This could cause your problem. If not I would think you need a rebuild<hr></blockquote>
Transmission is electronically controlled. As posted above, check your fluid first. If it's not the fluid, go for a filter and fluid change. This should clear it up.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
Aftermarket parts? Hitting your rev limiter? Stall speed? clean the valve body if all else fails....just DON'T flush the tranny....it causes a tranny failure 99% of the time with high mileage.Teal 94 Camaro 3.4 Liter<br />Transgo stage 3 shiftkit, Shift module, corvette servo, SLP cold air induction,3.42 ring and pinion, Heavy Duty Posi LSD, Flowmaster exhaust, NX, blackouts
the car only has 68,000 on it and the car is still completly stock. I was in the car when this happens.1999 Pontiac Trans Am M6 Far from stock.....
new update, were going to change the filter and fluid and stuff today. Also when when we rev it, won't go past 4000 rpms. It just bounces off it. Hopefull this clears it up.1999 Pontiac Trans Am M6 Far from stock.....
maybe its sensor went crazy, try disconnecting battery and reconnecting, that usually resets most of computer junk, then see if it shifts ok, if not, tranny rebuild sounds right, but you always have to try the easy things first [img]tongue.gif[/img]<a href=\"http://home.comcast.net/~beer13oy/carpage.html\" target=\"_blank\"><b>1995 3.4 Liter M5 Camaro</b></a><br />A few mods...<br />still slow.<br /><br /><a href=\"http://www.mnfbody.com\" target=\"_blank\">Minnesota F-body</a>
If thats true then that sux. We changed it and he has no first gear or overdrive now :( . We think we had everything in right, the filter. The more fluid it lost the worse it got. So we left the car at my house and see what we going to do tommorw mourning. Maybe have someone look at it and see what our options are.1999 Pontiac Trans Am M6 Far from stock.....
i forgot to say its leaking GRRR! I feel kinda resonsible for this myself sigh.1999 Pontiac Trans Am M6 Far from stock.....
