Do I need LSD?? (not the drug) - FirebirdV6.com/CamaroV6.com Message Board
  • Do I need LSD?? (not the drug)
    what does LSD do? and do I need it or is just the $240 ring and pinion from slp sufficient?
    The slp package comes to like $700+!!!! a LOT of money. Will i get the same gains by getting just the ring and pinion or do I have to get all of it??
    P.S. Rite now i have 3.08's and want 3.42's if that helps
    LSD let's both your tire's spin, should only be like $100. Ring and pinion is what changes your gearing (I think), with 3.08's i doubt you need LSD, but if you upgrade gears you almost certainly will.
    New Car: 2004 GTP Comp G (Test Vehicle) 13.936@99.32 <br />Mods: Cylinder Filter,No Mufflers, 3.3\" <br />Old Car: 2000 Formula 13.124 @ 106.01 with 2.73\'s<br />Other Car: 1993 Firebird 16.1@83
      so if LSD lets both tires spin then posi traction is the oppisite with only one tire spinning, rite?
        Nope. Posi trac has both tires spinning too. It's a little bit different then LSD though. With one tire spinning it is an open differential.
        2001 3.8L Firebird M5<br />Flowmaster 80 series,exhaust cutout,catco hi-flow cat,tbyrne WRA,whisper lid,K&N filter,BMR LCA\'s,Ram air H.O. hood,3.73 gears with LSD 17\" by 9 1/2\" TT2\'s<br />Rockford 300s with 2 12\" JL audio W3v2 subs and JVC HU
          i love to borrow this from dom..and im sure he doesnt mind ;)
          http://www.angelfire.com/my/fastcar/diffey.html
          explains all the differentials
          1992 Camaro RS<br />Performance: K/N filter and custom CAI<br />Stereo/Electronics: 10\" Kicker Subwoofers, DEHP-4400 Pioneer Head Unit<br />Maintenance: New brake lines, New transmission mount<br />Upcoming: Flowmaster American Thunder Catback, Catco Catalytic Converter
            or if you wanna know even more
            all about diffs
            -Brad
            2000 V-Star Custom 1100
            :rock:
              You have a 2 series carrier now, so if you're getting 3 series 3.42's, you'll need a new diff anyway and the $100 LSD is worth it. In fact, you'll pay enough for the install and everything, you might as well get the LSD. You will need an install kit for the gears and something to reprogram the car unless you want your speedo/odometer to be off.
              Chris
              <b>2002 BSM TransAm WS.6 M6</b><br /><b>350rwhp, 365rwtq</b><br /><b>Stock:</b>13.455 @ 105.39 2.129 60\'<br /><b>Mod:</b>12.449 @ 113 1.832 60\'<br /><br /><b>2004 QSM GTO M6</b><br /><b>303rwhp, 329rwtq</b><br />Stock: 13.74 @ 102.14 2.1 60\'<br /><br /> <a href=\"http://members.cardomain.com/silvertaws6\" target=\"_blank\">http://members.cardomain.com/silvertaws6</a> <br /><br /><b>1984 Firebird S/E M5</b><br />2.8L
