Throwout Bearing - FirebirdV6.com/CamaroV6.com Message Board
Throwout Bearing
  • Throwout Bearing
    Has anyone ever had to get their throwout bearing replaced? How much does it cost?
    How much does the throwout bearing cost? or how much does the install cost?
    The bearing is pretty cheap and usually comes with a clutch set. The install should cost you almost as much as a clutch replacement because they have to do almost the same amount of work like taking off the tranny and clutch.
    ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
      The throwout bearing is not cheap 69.95+. It apparently is not the same as the cheap V8 bearing.
      97 RS, M5 Y87 (3.42rear, posi, a/c)<br />35mm/25mm solid swaybars, BMR moly STB, alum DS, adjustable panhard bar, GM ZR1 17X9.5 w/275/40 BFG KD\'s, 360lb front & 140/170 rear springs, Koni SA shocks, poly bushings all round. CAI K&H filter, 160 thermostat, Edelbrock cat back, rollbar, pair red competition seat & belts,red carpet & door pannels, redline lubricants all round.
        You're probably right. I think I was thinking about the price of the pilot bearing. I looked around the net but couldn't find an exact price on the throwout bearing.
