I have a 1994 Camaro with the 3.4 and an automatic transmission. I was wondering if anyone has ever bolted a Z28 Rear right into the car, I mean take out the old V6 Rear and just put the Z28 Rear end in with the disc brakes. I want to convert my brakes over to disc anyway, I have already read the article that was posted about them on this site. And another question I have is do I have to reflash my computer because of the change in gears.
Rear End Swap Ideas
Yes, swapping the Z28 rear end is the easiest way to to get LSD gears and disc brakes. People do it all of the time. Just make sure you get the right year for TCS and what not.
Yes, you'll have to reflash your PCM for the change in gears. You can drive without re-flashing, but your speedometer will be off and your limiter will be lower.-Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
Keep in mind;
The Z28 rear is a "Direct Bolt-In". No modds needed. Any 93 thru 97 Z28 rear will work perfectly for your 94 3.4.
The only thing you'll need is Emergency Brake Cables for disk brakes. The ones currently on your drum setup are not compatible. Other than that, you're good to go! :Dsigpic
yep did it, its actully pretty easy...
Just really need to bleed the brakes well, only problem I rain into, took forever to get all the air out.
direct bolt in, easy swap, for the most part.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
I did it too, put a 2000 in my 99. Great rear end. Easy swap. Had it done in two hours using a friends shop. Speedo still off though :( Went from open 3.08's to LSD w/3.42's.Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
Originally posted by V6Cam:
how much would this send the speedo out of wack...where can you get the PCM reflashed, a dealership, or a aftermarket place...???
older cars, OBDI think is harder, newere ones you can do it wiht hypertech, or hptuners.
But in my opinion if your cars is old and you hae a 5-speed, doesn't matter if your speedo is off, just know by how much and your fine, only thing to worry about is your odometer. But if your car is like 100+k doesn't really matter too much what your mileage is.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
z28 cluster won't fix speedo problem...
not sure on the costs of getting the comp reflashed.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...1 week ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 weeks ago
