Can anybody tell me what the torque requirements are for both the transmission pan, and the differential cover. I really need to just go out and just buy a service manual for it, and then I wouldn't have this problem, but thanks in advance. BTW, I have a 2000 Firebird, auto transmission.
Trans. and Diff. Cover torque specs
Not off the top of my head. I would have to look it up. On stuff like that I usually don't use a torque wrench anyways. I just bring out that tool when it has to be exact precision. (i.e. head bots, caps, etc) stuff like that. :DThanks, <br />JAM<p>02 Firebird GT
tranny pan: 96 to 120 in-lbs
I can't seem to find the spec for the diff cover in my Haynes manualsorry
~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
rear dif cover .. just tighten it very tight.
15 ft/lbs perhaps. I don't really use a torque wrench.. just tighten it as tight as i can pretty much with a small 3/8" drive.
If you use a gasket and not gasket maker, it makes the job much easier as the gasket maker always gets inside of bolt holes and seeps over edges..
My diff cover is off bi-monthly and the first time it had gasket maker on it.. made the job twice as long... I even re-use the gasket sometimes.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
Thanks for the tip. I went to the dealership and bought the new gasket. I've heard though, that some use a combination of the new gasket and the gasket maker stuff. Have you had any problems with leaking just by replacing the gasket?2000 Red Firebird W68
no leak problems with just a gasket.
I really try to avoid gasket maker on the rear end. It's a big mess.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
No leaks with just a gasket here either. I was so afraid it would start to leak after I put the cover back on with a new gasket, but no problems after 10k mi.
[ January 07, 2003: Message edited by: Dojo2000 ]</p>~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...5 hours ago
