I know there are 6 bellhousing bolts but my question is are all six bolts the same length or is one longer and five are the same? Does that one that is longer go around the starter area? here are the gm part numbers i got are these the right numbers?
11515778
11508580
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
if memory serves me right they are all the same. but arnt there 4 or 5 bolts and 2 studs at the bottom? i seem to remember that being the way mine was. it may be 6 but im pretty sure they are all the same lenght
If I remember right there were 4 bolts around the bellhousing and a stud on the passenger side. Maybe 5 bolts, but either way there is definately one longer than the rest because it goes all the way through and has a 15mm nut on the other side.
-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
