is my axle bent? - FirebirdV6.com/CamaroV6.com Message Board
is my axle bent?
  • is my axle bent?
    as you all know i hit the curb the other day with my back right tire hard enough to crack the rim. well i got a new wheel and remounted tire and got it balanced. Now my right rear wheel is squeaking like no other and is really wobbley when i drive. Do you think i bent my axle?
    <a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'s
    I need to know asap!
      Could be. Put on a rim you know is straight, get the back end in the air, have a buddy look at the wheel while you put it in drive. (Do all the safety stuff plz, chock the wheels so you dont drive through a wall) let the wheel rotate and if it moves side to side or up and down, then yes you do. I believe we have 28 spline axles, if you need a new axle shaft
      Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
        How much does a new axle shaft cost?
          a set of new moser shafts cost $300. never piced new ones from GM. try looking for a used set from a junk yard.
            About how many hours would it take a mechanic to put a new shaft in??
              If it's on a lift and he knows what he/she is doing, no more than 1 hour.
              -Remove rear cover and drain fluid.
              -Unbolt brake calipers from backing plate and remove from rotor (remove the rotor too).
              -Remove bolt from the pin in the center of the gears and remove pin.
              -Push axle inwards towards the center of the car and the C-Clip will fall off.
              -Pull axle out.
              Installation is basically everything here in reverse. Don't forget to replace fluid. ;)
                well, its not about how long it takes him, its what your going to be charged for the job. independent shop or not.
                2000 3.8 A4 Pewter Camaro
                  I dont get the last part. I thought they got payed by the hour?? its an independent shop.
                    Some charge by the hour, some charge per job.
