Rear Axle Play - FirebirdV6.com/CamaroV6.com Message Board
Rear Axle Play
  • Rear Axle Play
    Is it possible for the rear axles to become loose, If so what would cause it?
    96 Polo Green Camaro<br /><br />Slp Cai,Flowmaster American Thunder cat-back,Catco cat,3.42 Posi rear, KMC Floss Rims 275/45/17 rear 235/45 front
    like where they come out of the housing?
    c-clips?
    I guess I\'d have answer your question with another question.<br /><br />How many Abidiginals do you see in modeling??????<br /><br />headers, 3inch magnaflow cat, Loudmouth<br />99 Midnight Blue Firebird<br />3.8L A4
      No, not actually all the way out but it just seems like there is too much play in the passenger side axle. Its like its bouncing around in the housing.
        Axle bearing could be going bad. Does it make noise while rolling? Typically bearings will roar when they are on the way out.
        1999 Y87 Camaro<br />Whisper Lid, SLP SS Takeoff Exhaust
          No, it doesnt make any kinda noises except for the loose rattling noise. I was thinking maybe its a bent axle,but im not sure how to tell. It didnt always make this noise. It started a few weeks after my rear end swap.
            If you think it is a bent axle. Prop your car up on jackstands, and make sure the car is in neutral. Then spin the tire, *fast* and see if you see the tire spinning unevenly.
            FTRA kit, Whisper Lid, free ram air mod, Richmond 3.73 gears, Dynomax Catback, Poly Tranny mount, Vette Wheels, Expensive Audio equipment :). HID headlight Kit, Billet Grille, Billet Antenna, Eurotails, Carsound Cat
              Cool,thanks ill give it a try.
                The way I found out that my rear axle was bent was when I machined my rear rotors. Out of curiosity, I bolted the rotors to the hub during reassembly and turned the whole thing. You could see the rotor move from side to side inside the caliper indicating that the back axle was bent. The caliper because it can sit in one spot really close to the rotor is a good way to tell if you have a bent axle or not.
