Weird 2000-3000RPM loss of power. Help! - FirebirdV6.com/CamaroV6.com Message Board
  • Weird 2000-3000RPM loss of power. Help!
    My camaro has 120k miles, and the previous owner said he hadn't replaced the clutch. Like I mentioned before I'm getting a weird loss of power from about 2000-3000RPM when the engine is under load. It feels like something isn't catching, like something is slipping. It's like a weird surging thing. Could it be the clutch slipping? Would it just do it at that RPM? My other guess would be the fuel injectors, or maybe the fuel filter.
    Got any ideas? I sure apprecite the help! [img]graemlins/burnout.gif[/img]
    95 Med Quasar Blue Camaro M5<br />-free ram air scoop<br />-removed silencer/cut airbox<br />-slp air temp module<br />-tb bypass<br />-160* thermostat<br />-underdrive pulleys<br />-installed my own t-tops! best mod yet!
    Get up to cruising speed in 5th gear, then mash on the gas. If your RPMs rev up and the car doesn't accelerate at all, then your clutch is slipping. If it slips, its all down hill from there. Gradually over time it will rev higher before it catches, then one day it won't catch at all. :(
    ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
      My car has the same problem, and my clutch was replaced not too long ago... Im eager to see what is said about this.
        <blockquote>quote:</font><hr>Originally posted by Dojo2000:
        Get up to cruising speed in 5th gear, then mash on the gas. If your RPMs rev up and the car doesn't accelerate at all, then your clutch is slipping. If it slips, its all down hill from there. Gradually over time it will rev higher before it catches, then one day it won't catch at all. :( <hr></blockquote>
        well, i tried that, and it ain't my clutch. any other things to try? thanks! [img]graemlins/burnout.gif[/img]
