Hey i have a 96 camaro with drums in the back. I cannot find a rearend for drum brakes anywhere. I found one with 20k on it for 500 with disc brakes. It is a lsd with 3.42. My question is what all is involved in changing drums to discs in the back and how can i make it fit?
Need help on LSD and disc brakes
1996 Camaro -- SLP CAI, Motorvator TB spacer, MSD 8.5 mm wires, 180 thermostat, Pacesetter headers, Catco 3 in cat, TSP Rumbler, custom painted interior, 18x9.5 Z06 replica wheels, Nexen N3000 265/35r18 tires, - Best 1/4 mile 15.3@89mphTags: None
www.turbov6camaro.com
1997 3800 Series II Camaro
Go to the search button up top. You'll get all the info you need on swapping the rearends, or follow viper04af's guide.sigpic
Dude, you would have to be crazy not to go with the rearend that only has 20K on it and discs! In addition to that you're also getting a LSD with 3.42 gears... and all for 500 bucks?
The benefits of 4-wheel disc and a LSD are obvious.
Good Luck though, i hope everything works out.2000 Monterey Maroon Chevrolet Camaro<br />3.8L V-6/4spd Auto
Well I wouldn't call him crazy. I was able to get my Z28 rearend with rear disks (didn't need them) for $425 shipped. If that is all that you can find at the moment then I say go for it. Changing over from drums to disks is not bad at all and disks are definately better. Take a quick look around to see if you can find a better deal, if not go for it.98 Silver Camaro V6<br />15.238 @91.74 w/ 2.288 60\'<br />Mods: K&N, FTRA, Pacesetter Headers, Spec 3 Clutch, 160 Thermo, TSP Rumbler, 3\" Catco, Whisper Lid, 3.42\'s w/LSD, Aluminum DS, Man Fan Switch<br /><br /> <a href=\"http://www.cardomain
I am going through this swap right now actually.....I got a deal on a complete rear with 3.42's from a 2000 WS-6 with 15000 miles on it for 150.00 :D .......
The problem I am going to have is not being able to use my ABS because the new rear is a 4 channel
Not sure how to handle that one yet......Eric
2005 Mustang 4.0
1996 Camaro Conv
2000 Ford Excursion
"Darkness Falls"
Merlin, I also picked up a 3.42 Auburn TCS rear and was looking very closely at how to make it work.
Brake lines: not really a big problem. Simply replace the mismatched left/right lines with ones that end in the same size threads. Then the existing T fitting and single rear line can be reused.
ABS: not sure what's going to happen here. The connector (where it plugs into the port on the car) is the same size and shape, only the new one uses 2 more wires than the stock. Since the stock 2-wire colors are in the same position on the plug as the 4-wire, I'm wondering if it wouldn't still work, just only reading from one of the axle sensors? Only reason I can think of why it wouldn't work is that the ABS computer is expecting a certain number of pulses from the rear in relation to the front (it monitors wheel speed) and of course the axle sensor gears are much smaller than the diff sensor gear, so is the computer going to throw a fit if it thinks the rear wheels are turning much slower than the front wheels?
<edit> RE the original question, try to get a rear that matches your drum rear. If you have TCS/4-channel ABS then try to get the same configuration. If you don't have TCS try to find one with the single brake line input and ABS sensor.
Make sure to get the e-brake cables from the new rear along with the calipers, rotors, etc.
[ September 16, 2004, 06:02 PM: Message edited by: FunkZ ]1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...1 week ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 weeks ago
