About how much power/torque can a V6 rear withstand?
V6 rear end strength
Its the same rear the V8s come with, so you should be fine unless u have some crazy plans. I am not sure about a horspower/torque number, but the two fastest cars on this board still have the stock rear.92 S10 3800 A4(96)<br />1/4: 14.374 @ 92.25 w/ 1.976 60\'<br />Turbo and 12\'s Coming Soon!
for the V8's it's not power that kills them. It;s traction. you start getting under a 1.8 60 foot. start to watch out.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
The rears are the same, but the 2-piece V6 shaft won't take as much abuse as a V8 1-piece. You can easily swap shafts for a 1-piece though.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Every 3.8 I've seen had a 2-piece. 'course those have all been mid-late 90's cars. Did GM start using a 1-piece in the later V6?
1 piece here.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
1 piece on a 2001 then? Anyone know what year GM made the switch?1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
some random V6's got the one piece in the later years, but as far as i know you got a 2 piece unless you got lucky......www.turbov6camaro.com
1997 3800 Series II Camaro
Originally posted by chas:
y87's have the 1-piece shaft.
Instead of guessing, maybe you all should read the Technical Database. Read 1998 and 1999.
http://tech.firebirdv6.com/general.html
:rolleyes:Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...1 hour ago
