Pinion seal leaking? Is there a GM service bulletin on this?
How many here suffer from...
mine leaks all the time...i've put a new on in like 4 or 5 times...never made a difference...so now i leave it...it leaks very slow so i just have them top the oil off with every oil change...im hoping the 3.42 diffy will make a difference...but im not exactly sure where that seal is<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
The pinion seal is in the rear of the housing (or towards the front of the car). If you get an install kit when you change gears you should be getting a new seal with the kit. So basicly if your seal is leaking you have an excuss to swap gears since who ever does the job will have to pull the old gears out to replace the seal.Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
sweeeeet...cuz im buying the install kit when i change gears...so hopefully that'll do it<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
I have also done the rebuild and mine still leaks. I must have changed 10 of these pinion seals that I have put on ever since the original one was replaced. It's good I'm not the only one here suffering from that dilemma but also its bad that everyone has this dilemma.<i>00\' NBM Firebird~T-5<br />60\': <b>2.29 sec.</b><br />1/4: <b>14.7 @ 95.5 MPH<br />Ask not what your country can do for you, ask what you can do for me.</b></i>
when i did the gears on mine it would leak but it wasnt the seal leaking it was coming out through the splines on the pinion gear, so i pulled the nut off and put a crapload of teflon paste and re-torqued it and there hasnt been a drop come off of it for about 5000-10000 miles<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
had it on my 94 before I did a rear axle swap.(actually one of the reasons I did a rear axle swap)
so far *knock on wood* no problems on my current car but I have a spare pinion seal just in case, I bought it thinking my old one was gonna be toast in my 94, when I broke the torque arm and rotated the axle a bit.
Yeah, I know this is an old thread, but where do you fill up the oil in rear diff? Mine like all F-Bodies leaks a few drops of oil everynow and then and I was wondering how to top it up.1996 Camaro Y87 5-Speed<br />K&N filter<br />15.19 @ 89.84
There is a 3/8 square drive plug on the side of the diff, about 3/4 of the way up the housing. Use a 3/8 drive rathet with an extension to unscrew it, and make sure the fluid level is right up to the bottom of the hole.
- Justin<a href=\"http://www.njfboa.org\" target=\"_blank\">New Jersey F-Body Owners Association</a><br />1987 Camaro LT - 400sbc, Aluminum L98\'s w/valve job, Comp XE 274, Q-Junk 750, 3.23 posi, 4.10\'s soon.<br /><br /><a href=\"http://www.njfboa.org/forums/viewforum.php?f=11\" target=\"_blank\">East Coast F-Body Nationals - August 14, 2005</a>
