water in the diff? - FirebirdV6.com/CamaroV6.com Message Board
water in the diff?
  • water in the diff?
    I work for the local police department here and during the last hurricane i had to make an emergency relocate in the middle of it. i had to drive the bird cause the wife had the truck and well i drove thru about 6in of water for about 300ft, but i drove very very slow, so is there any possibility that i got water in thru the pinion shaft?
    jon
    {1995 3.8 A4}{Flowmaster Exhaust}{SLP CAI & Fan Switch}{4 Wheel Disc Brakes}(3.42 LSD}<br /><br />{2004 Dodge Dakota SXT 3.7L SOHC V6}{Cold Air Intake}{Dynomax Ultraflo 2.5\" Catback}<br /><br /> <a href=\"http://members.cardomain.com/95blackbird3800\" target=\"_blank\">http://members.cardomain.com/95blackbird3800</a>
    Probably not...the pinion seal should have kept it out....but our cars are known for leaky pinion seals.
      yes. your best bet is to be safe and change the fliud. it can also come in through the axle tubes
      1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> &lt;Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> &lt;Fbody Tech Articals
        I wouldn't think that you got any water in the diff through the pinion shaft. There is a seal on the pinion. That doesn't mean that it's impossible for water to get in there though. There is a breather on the top of the passenger side axle housing, but it's designed with a cap to where fluid can't just flow down in. I think you're prolly ok. If you still feel a little worried, now wouldnt be a bad time to replace your fluid and be sure to put some LSD additive in there if you have LSD.
        ~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
          Geeez, it's a good thing we all posted at the same time. I didn't even know you all beat me to the response.
            changed the fluid and put in some gm lsd, but i didnt see any water and the fluid was perfect so oh well, its done now.
            thanks, jon
