M5 People - Shifting Into Reverse :) - FirebirdV6.com/CamaroV6.com Message Board
  • M5 People - Shifting Into Reverse :)
    In many FWD cars it helps tremendously to shift into 2nd gear before going into reverse.
    MTMike helped me out with this and I just thought I'd post that in our RWD T-5's you can shift into reverse without ever grinding a dog tooth off by shifting into 5th, waiting a second with the clutch depressed, and then pulling it back into 1st. It stops the syncro's and really makes shifting into reverse a breeze.
    Just a little FYI
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
    I always just do 5th to reverse.
    2002 M5 Bright Metallic Silver <br />*Fully loaded and modded<br /><br />2005 GSXR 750<br />*Micron Serpent Race Exhaust *K&N Filter *Power Commander *Trying to hit 200 MPH!<br /><br />1970 SS 454 Chevelle Cortez Silver<br />*It can pass anything but a gas station
      it really doesn't matter which gear just any forward gear will stop it from grinding.
      i was swimming in the carribean. animals were hiding behind the rocks except for the little fish, but they told me the squid\'s trying to talk to me. oink, oink. where is my mind?
        I'm gonna have to try that, I was about to post asking about it!
        www.RedLineVSix.com || 1996 Camaro, 15.159@92.5mph
          well I have also found that sometimes I try to put it in reverse and it just won't go.. not grinding just doesn't go... so I usually drop it into second... ease off the clutch just a hair.. depress clutch drop it into reverse and go..
          -Brad
          2000 V-Star Custom 1100
          :rock:
            Thanks for posting that!! Mine grinds reverse all the time, and if this works that would be GREAT!!
            2002 Camaro V6, M5, Black, T-tops, Y87, Monsoon, and Leather!<br />**Current Mods** : Wisper Lid, Hurst Billet Shifter, Free CAI.
              my reverse always grinds jus a little finesse works i find sometimes its a ***** to get it in. torque the throttle a bit and it drops right in but i always announce it to 5th then drop it down into reverse, the same for first i like to announce 2nd then up into first its alot easier on my tranny.
              •)))2000 3.8L V6 FIREBIRD (Navy Blue) 5 speed <br />•Aluminum Alloy 3-piece custom built wheels - 17x10 (front)- 17x11.5 (rear) Tires:Front: 275/40-17 - Rear:315/35-17• Suspension Techniques 1 3/8 \" Solid front Sway Bar• H&R Springs • Koni revalved double adjustable shocks (front)• Bilstien Custom Revalved shocks (rear)• K&N •Magna Flow Dual Exaust• Stock wheels W/Hoosier Road Racing tires • Sound System•<br /><a href=\"http://www.cardomain.com/id/o0oskamo0o\" target=\"_blank\">•THE RIDE•</a>
                yea....I always do the 5th to Reverse and it works all the time for me.
                <b>99\' Black Camaro SS</b> <br />M6/T-Tops - SLPLid w/K&N | Hurst Billet Plus w/ LSS | EGR Mod<p>Black 97\' Camaro T-Tops (RIP)
                  yeah...any forward gear to reverse stops whatever's grinding from moving, causing the grind.
                  however, if you want to save your gears even more...you can just put the clutch in, and let whatever's moving stop...and no grindy [img]smile.gif[/img]
                  2011 Camaro LS 6M, in black.
                    It only grinds because reverse is spinning backwards and isn't a syncro gear - sucks. I wish they gave us syncro reverses!
                    I've not been able to use any forward gear, only 5th works for me - so thats why I recommend it. [img]smile.gif[/img]
                    Sorry to hear all that grinding everyone, maybe you guys won't gind your dog teeth so much now eh? [img]graemlins/toto.gif[/img]
                      I always do 5th to reverse too and have never had a problem. I also go from 2nd to 1st too becuase sometimes 1st grinds as well
                      1996 Silver Camaro, Y87, M5, cammed..<br />N/A Best Time: 14.012 @ 98.59<br />195 rwhp / 233 ft-lbs b/f heads/cam<br />Check out my site <a href=\"http://silver3800.cz28.com/\" target=\"_blank\">http://silver3800.cz28.com/</a>
                        Put me into the '5th to reverse working just fine' group too....then again, I did just have my 5th gear synchro go out. Hmmmm....wonder if there's any relation there.
                        Mods: <br /><ul type=\"square\"><li>Appearance: \'CAMARO\' Reflective Concepts Lettering, 3800 V6 Reflective Concepts, Clear Corners, Aluminum Billet Grill <li> Performance: Borla Cat-Back Exhaust w/ Quad Tips, Hurst Comp. Plus Shifter w/ Lou\'s Stick, SLP Fan Control Switch, Powerstat, AAA Aluminum Rims, Whisper Lid, K&N</ul><p>Photo: <a href=\"http://is.uth.tmc.edu/dp/smyles/bluemaro.jpg\" target=\"_blank\">http://is.uth.tmc.edu/dp/smyles/bluemaro.jpg</a>
                          if reverse had a synchro...if you missed a 4th gear shift too far down to the right...you'd lose your tranny. reverse doesn't have a synchro for a reason. hold the clutch in for about 3 seconds...then try to shift into reverse without touching any other gear. no grind. been done, tried and tru.
                            <blockquote>quote:</font><hr>Originally posted by navyblue2000:
                            if reverse had a synchro...if you missed a 4th gear shift too far down to the right...you'd lose your tranny. reverse doesn't have a synchro for a reason. hold the clutch in for about 3 seconds...then try to shift into reverse without touching any other gear. no grind. been done, tried and tru.<hr></blockquote>
                            What works for you doesn't work for me.
                              <blockquote>quote:</font><hr>Originally posted by Blue Flame V6:
                              <hr></blockquote>
                              ok, try 5 seconds [img]tongue.gif[/img]
                              it does work though, i know.
                              • Manimal
                                Coil springs
                                by Manimal
                                5 days ago
                              • Manimal
                                Newby here
                                by Manimal
