synthic differential fluid question? - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Use Royal Purple.. it rocks
    • #17
      Yeah, sorry, forgot to mention Royal Purple. They're up there in the top tier too. But Royal Purple isn't as easy to find in auto parts stores...
      • #18
        have a question, I got a '97 coupe(no Y87) with the T-5, I don't know if it has limited slip? Am also considering swithing to synthetic in diff. Could you also use the synthetic in the trans?
        • #19
          speedguy--no, you do not have a limited slip. You have a 3.23 open differential.
          For any automotive fluid on a high-performance car synthetic is always better. Oil, tranny fluid, differential fluid...
          • #20
            I've been running Mobil 1 for about 3 yrs now and haven't had any problems. As mentioned, I always pick up a bottle GM limited slip additive from the dealer. Also get a gasket while your there too cuz you will need to replace that.
            2000 Y87 Bird M5 with mods<p><a href=\"http://www.vzavenue.net/~ngeorg/\" target=\"_blank\">http://www.vzavenue.net/~ngeorg/</a>
