what kind of gears and lsd differential where to get them at - FirebirdV6.com/CamaroV6.com Message Board
  • what kind of gears and lsd differential where to get them at
    what kind of gears should i get and lsd differentials what website made them for a 98 3.8 v6 firebird
    Re: what kind of gears and lsd differential where to get them at
    well what if your an auto i would say get a posi, and 3.42's if you don't care about gas millage get 3.73's. if your a 5 speed get the posi with 3.73's and again if you don't care about gas millage get 4.10's. you can get them at lmpeformance and any other speed website. i got mine off ebay.
    WAWA-A-HOLIC
      does the Thunder Racing Complete Gear Package for GM 7.5" 10 Bolt Rear Ends come with Posi Limited Slip Differentials
      http://www.thunderracing.com/catalog...&vid=5&pcid=68
        y the difference b/w auto and manuals?
        2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
          its a 4 speed auto tranny versus a 5 speed... a higher gear ratio in an auto will have a slightly more pronounced difference.... i think...
            That kit only comes with gears, install kit(bearings, shims etc), lube, and a aluminum rear cover. An eaton posi unit would have added another 400 plus onto it. You can get gears and a posi unit for a 4th gen camaro almost anywhere. Try Jegs, Summit, Moser, Strange, DTS
            69 Camaro 350 4spd, Full Hotchkis susp, Baer brakes, moser 12 bolt, Flowmaster<br /><br />96 RS Hotchkis STB, subframe connectors, Hotchkis LCA and adj Panhard rod, SS camaro sway bars, Bilstein shocks, powerslot rotors, Borla exhaust, rksport headers, k@nFIPK
