DANM problem... - FirebirdV6.com/CamaroV6.com Message Board
DANM problem...
  • DANM problem...
    My tranny fluid just leaked out all over the drive way. I got under the car and replaced the tranny filter and the gasket, started up the car and it is still leaking horribly. The fluid is running from around the starter area and down the flywheel housing..WHERE can it be coming from:rant:
    somebody please help....I just put my car for sale and cant be dealing with this problem for long.
    Re: DANM problem...
    torque converter?
      Re: DANM problem...
      only way to find out is to look
        Re: DANM problem...
        I cant get a good look at where its coming from....the only place I can see it drip from is the bottom of the housing next to the little hole that is there. I took off my starter and put it back on about two weeks back, could that have ANYTHING to do with it.
          Re: DANM problem...
          No your starter removal had nothing to do with your leak.
          There are two possible leak locations in that area.
          1) Torque Converter seal located in the transmission pump housing. This is where the torque converter is inserted into the transmission.
          2) Transmission pump cover seal.
          To replace either one of those requires the torque converter to be removed, which in turn means that the engine has to be disconnected at the engine mounts, then moved up and forward a bit, then the transmission seperated from the engine and the drive shaft removed. This is no small task.
            Re: DANM problem...
            you need to take the whole tranny out and check the master/slave cylinder. that is probably where it could be leaking from. i just took mine out so no everything by heart. its the second time and could imagine that would be the problem
              Re: DANM problem...
              he has an automatic so he doesnt have a slave or master cylinder
              '99 Camaro Y87 M5 T-tops
              Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
              Car Domain
                Re: DANM problem...
                I dont know what it could be. Its too hard to tell exactly where its coming from...I only runs out when the car is running.
                  Re: DANM problem...
                  its either your torque converter or front pump. i dont know what the dude up there ^^^ was talking about when he said to **** with the engine but all you have to due is remove the tranny to get to it. needs to be toed to a shop unless you wanna try to fix it yourself.
                  2000 3.8 A4 Pewter Camaro
                    Re: DANM problem...
                    pretty much what he said...
                    pull the tranny.
                      Re: DANM problem...
                      well obviously you dont know what your talking about and couldn't understand a miss-interpretation of m5 and auto so be easy youngster. well i really think if you dont want to spend a good two to three hundred dollars id be better just to take it out and take a look.
