yes you probably need it. if the gear swap requires you swap the drive gear, the you will need a new crush sleeve. it will probably come with a new gasket for the cover and a pinion seal if you do need to replace it. hopefully some contact pattern paste also so you can make sure your contact pattern is correct still.
do you have to remove the drive gear? if so, do you have the tool to hold the yoke or an impact? you will have to press th bearing off and put it back on also.
anyone near ILLINOIS that would help me put in my lsd and 3.73s for 2series carrier when i find some..? do you need anything if the gears were actually made for a 2 series?
I would help you if I lived by you, but it would end up being me doing all the work... not just teaching. Noone is gonna recommend you do your own gears.
FACT: It is TOTALLY worth it to have a shop install them! and I stand by that statement 100%!!
I can however give you links on how to install them
those links would be great man and do you know the answer to my second question.. " do i need the install kit if the gears are already for a 2 series?" what all would i need?
kinda, no reason to upgrade the gears if you dont have an LSD/Posi
If youre gonna do it do it right, used LSDs are not that expensive
with 3.73s in an Open differential you will do burnouts real easy and not get
traction off the line. Of course the 3.73s are gonna limit your top end a little
What setup are you going for?
Drag race car?
Track car?
neither?
I'm gotta warn you its impossible to do it without the gear install kit. It might take you maybe like 10-15hrs. You might not even do it right
'96 Trans Am M6:) Cam, lifters, 1.6rr, lt4 springs, 4 bolt mains, long tubes, TDs, short throw...etc
'99 Firebird SOLD 1/4 mile 15.4 @ 86
'66 Ford SOLD
2 days ago
