Hi everyone. I have a good deal on a 2-series carrier from a 98 trans am, and I was wondering if this carrier (7 1/2 - 7 5/8, 10 bolt, 28 spline) would work in my 99 v6 camaro with 3.08 gears. Thanks.
Rear Differentials
Re: Rear Differentials
O sorry for the confusion guys, I am wondering if there is a 2-series posi, or if only 3-series carriers are posi. I have an open differential with 3.08s, or at least I assume mine is open because when I do a burnout, only the right rear spins. Sorry for the mix up
what would you use 3.08s for? the Autobahn?
I would AT LEAST step up to 3.42s!!!
3.08s = bad city mileage2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
i have a stock 1 off a z28, its not installed but i dunno if it matters or not what series the posi is... the guy i bought it from said it is out of a 2 series though, just double check if it will fit a 2 series thats what i did..
Yes you can simply swap your existing open carrier for that 2-series LSD from the T/A. All V8's came with limited slip as standard, whether they had 2-series or 3-series gears.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
