I need a 2-piece driveshaft - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: I need a 2-piece driveshaft
    but why????? the aluminum is stronger, lighter better balenced, easier to install, easier to maintain, and not much more money, where is the bad
    K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
    • #17
      mine has the u-joints fine. if you want it email me and we will work it out.
      v6rs97@aol.com
      1997 Camaro LS1 RS
      1994 Camaro - Sold
      1999 Trans am Vert - Sold
      A Few Mods....
      • #18
        How is aluminum stronger? or better balanced?
        Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
        • #19
          aluminum ones arent stronger.. but they are lighter.
          '95 3.8L A4 PGM. & '95 LT1 M6 PGM. :burn:
          • #20
            Now I'm wondering if it will even bolt up to an LS1 car? Where does the center support bearing bolt to the car?
            • #21
              im pretty sure it'll bolt up. The LS1 DS' fit on the v6s meaning theyre interchangible. Why would youwant a 2 piece ds?
              Mystic Teal Metallic
              • #22
                why on earth would you want a 2 piece... its junk.
                i heard the only reason GM did used them is they had alot of small driveshafts around and they modified them into 2 pieces.
                They are the heaviest of all, they are the weakest of all.
                If an aluminum is too much, then go with a 1 piece steel.
                If you have vibration or other issues, just take the thing to a drivetrain shop and have the u-joints replaced and balanced.
                As for the 2 piece, you need a 2 piece driveshaft car torque arm as well, that where the center bearing bolts on to.
                I think you are plum retarded if you put a 2 piece in. That thing gave me and caused troubles in my 3.4L, it sucked.
                • #23
                  The reason GM used them is that they don't vibrate like the 1-piece driveshafts do. Thats the reason I wanted one. They are much more expensive to make, so there is a reason GM used them.
                  Price has nothing to do with it. This is for a 98 formula, it came with the aluminum from the factory.
                  My 99 v6 also has the aluminum, and it has the same vibration problems, as the 98, but the 98 is a 6-speed, so its much more annoying.
                  I appreciate all the help, but I'm going carbonfiber. rather than go to the trouble of swapping the torque arm.
                  • #24
                    just take it to a drivetrain shop, get them to rebalance it.
                    I have had 2 seperate 1 piece steel, and one aluminum and I NEVER had a vibration problem with one of them.
                    I did have a huge problem with my 2 piece when the center bearing went bad.
                    • #25
                      Dude, if you want it, i've got mine sitting right here. All ready to be shipped out, just took it out this morning. It looks fine, all the u-joints looked good, nothing wrong with it. Let me know if you're interested radracer513@hotmail.com
                      ~97 3.8L V6 Camaro~
                      A few things
                      Only Member of Team Hooker?!?
                      • #26
                        I have one as well, shoot me a quote, i just pulled it out 2 weeks ago. I also have the torque arm with the mounting plate for the 2 peice.
