I have a question related to replacing the differential gasket. Do I need to use any type of sealant on the metal surfaces, or do I just put on the new gasket and tighten that down?
Differential gasket change
Re: Differential gasket change
u shold use a gasket sealer. i dont think u have to, but it could cause leaks down the road. i always use sealer. dont over do it with the sealer eitherHeady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
personally i wouldnt even use a gasket just good silicon but if your going to use one put a small bead on both sides of the gasket to make up for surface abnormalities(?) an make sure you clean both surfaces well
I would recommend not using sealant. just the gasket
I would say use a small bead of sealer in addition to using a gasket.
I just used a gasket on my differential when I changed the fluid and it leaks. Not to the point where it drips on the ground, but the fluid has leaked around the diff area.....and yes, I cleaned both the diff housing and diff cover surfaces.--<b>David</b>--<br /><a href=\"http://bryant2.bryant.edu/~dsantore/index.htm\" target=\"_blank\">The <b>NEW</b> V6Bird Website!</a> <br /><a href=\"http://members.cardomain.com/thev6bird\" target=\"_blank\">Cardomain site</a><br />ΔX
yes ,I am a GM Technician, I have done this stuff regularly, and you do tighten like a wheel to 26 ft/lb according to yr model 2000.
Originally posted by jrschultzHe should know right?
everyone didn't fall from the same tree
Originally posted by BLLDOGGyes ,I am a GM Technician
I say we tie him up and feed him to this guy ---> :banana:
J/K :)
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...7 hours ago
