quick question. - FirebirdV6.com/CamaroV6.com Message Board
quick question.
  • quick question.
    I bought 1 quart of gear lube for when I change the differential gasket. Is that enough or will I need more? The guy at the autoparts store didn't know.
    Re: quick question.
    Nevermind the above question. I finally found my manual and realised I needed 1.75 quarts. I put in the 1 quart I had. Will it be ok to drive until I get to the auto parts store tomarrow to get another bottle of gear lube?
      Re: quick question.
      how far is the autoparts store if its within a couple of miles youll be fine just drive slow to keep heat down
        Re: quick question.
        Yeah its close. I just wanted to make sure I would be ok. I knew I should have bought 2 bottles.
          Re: quick question.
          do you have LSD? if so, you need the additive
          2000 3.8 A4 Pewter Camaro
            Re: quick question.
            No, but thanks for the reminder.
