will an f-body run faster with stock 16 inch rims, or 17/18" chrome Z06 rims?
rim size question
Re: rim size question
You are correct. Inertia is what causes resistance, inertia is based on mass (weight) and radius. More weight = more inertia. More wheel/tire height = more inertia. However remember to compare total height (wheel plus tire) not just rim height.
This only applies to street cars, once you are running 11's or faster you want a drag slick with a taller sidewall for better traction.2001 Black Z28 M6<br />Sprayed, slotted, geared and more~
Originally posted by 00 Silver 6his argument is traction... were talking about a high 12 second 97 LT1 camaro. he says that the traction made by the wider tires outweighs the negative aspects of more "rotational inertia" (he thinks i made the term up)
Your launch is one of the most important aspects so traction would win from a stop, from a highway roll the car with the smaller inertia will pull ahead, although the difference may be so negligible that other small factors could determine the outcome of the race.2001 Black Z28 M6<br />Sprayed, slotted, geared and more~
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...15 hours ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...3 days ago
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...2 weeks ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 weeks ago
