rear end's - FirebirdV6.com/CamaroV6.com Message Board
rear end's
  • rear end's
    just a quick question, i want to put rear discs on my '97 firebird and the easiest way is to switch rear ends with a 93-97 trans am, correct? my question is could you use the rear end from a 93-97 Z28? thanks
    Alex
    Re: rear end's
    yep same thing.... only difference is if it has traction control or not.
    you will want one that does NOT have traction control(TCS)
      Re: rear end's
      oh alrighty, thanks man. :)
        Re: rear end's
        I will be doing this in the near future with my 97 as well. My question is, if the Z28 is sitting in a junk yard, how do you tell if it has traction control or not? What will I need to look for in finding out?
          Re: rear end's
          good question, thats what i forgot to ask. anyone?
            Re: rear end's
            none traction controle will have 1 line leading to the breaks the traction controle will have 2.
            None traction controle will have a T-valve over the pumpkin "diff housing" where the break fluid lines goto the calipers. and 1 will go into the front of the car.
            Traction controle the lines will leave the calipers and go to the center of the axle and both go to the front of the car.
            They break lines will run to the rear of the seats "under the car" behind the drivers side rear wheel . so when you look at the axle assymble look at the top of the diff house for a T valve where the calipers lines meet. T valve = GO V6!!
            I was also told but have not seen for my own eyes that the traction controle units have an extra electrical. becouse i was thinking just reuse my old break lines and boom? but if it is such a issue i guess its not that reay and the traction controle units seem to cost more?
              Re: rear end's
              a non-TCS rear had the ABS sensor in the top of the pumpkin, the TCS rear has the ABS sensors out on the wheels...there will be a sprocket on the end of the axle
                Re: rear end's
                this just came to me, why don't i want a rear end with traction control?
                  Re: rear end's
                  Traction control is a system, just like ABS, not a feature of the rear end. Having the rear does you no good without the rest of the system. The braking system of a traction control car uses a different setup on the rear, as stated previously.
                  Look for the NW9 RPO code - that is traction control.
                  http://www.funkz.net/firebird/rearendfaq.htm
                    Re: rear end's
                    Read the post above you: a non-TCS rear had the ABS sensor in the top of the pumpkin, the TCS rear has the ABS sensors out on the wheels....but i guess that wasn't clear enough. Sure, you can put a TCS rear on a non-TCS car, but you won't have your ABS active. There's nothing wrong with TCS, you run into problems when you try to mix the two
                      Re: rear end's
                      I just replaced my rear end, it was a pain in the arse.
                        Re: rear end's
                        old thread but did traction control come in the 93-94 z28's ?
                        1997 Camaro LS1 RS
                        1994 Camaro - Sold
                        1999 Trans am Vert - Sold
                        A Few Mods....
                          Re: rear end's
                          Looks like 97' and up was a option for traction control. Looking at salvage yards.
                            Re: rear end's
                            I don't think it did. The rear end i picked up off a 94 TA didn't have it (which was a good thing for me)
                            But maybe there was some kind of performance option for it those years? I dont know..
                              Re: rear end's
                              I think it was because they started to come out with disc brakes on the rears in 97'.
