On my 1999 Firebird 3.8l when I go around a turn, especially down a left hand hill turn, I hear a noise in the rear end. It's not a grinding sound but more like a tunk, tunk, tunk. But not all that loud. I don't hear it anywhere else, and I'm useually not accelerating. any ideas? I don't think its the bearings, but not sure...
Diffrential question
Re: Diffrential question
This goes in the drivetrain/suspension section? IDK
I would like to get a sound clip of that cause it sounds like something I've heard before? On mine, I can hear the rear driver's side spring uncompressing and slipping or something...2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Originally posted by OZZYSHOUSEOn my 1999 Firebird 3.8l when I go around a turn, especially down a left hand hill turn, I hear a noise in the rear end. It's not a grinding sound but more like a tunk, tunk, tunk. But not all that loud. I don't hear it anywhere else, and I'm useually not accelerating. any ideas? I don't think its the bearings, but not sure...
Im not a differential expert but my 98 y87 firebird makes the same noise and it also leaks oil from the pinion seal. I was told by a shop that the pinion bearing is wore out and and has some play back there which is causing the seal to vibrate and leak. I asked them if the noise I heard had anything to do with it and they said that it is probably the wore out pinion bearing. I'm having the car looked at by another shop tomorrow and they are gonna see how bad the damage is. If that bearing put any wear on the other bearings and gears then I'm basically gonna need all new guts to go in my differential which is gonna cost a pretty penny. If I were you, I would take your car to a shop and let them take a look at it.
I had a noise that happened on drivers side turns only too, likewise at the end of the turn, it would make the noise repeatedly a couple of times.
I fixed it by replacing the drivers side wheel bearing seal
hard to tell what kind of noise it is w/o a sound clip tho1999 Camaro Z/28
1973 Firebird Formula
I've got a grinding noise when slowing down, usually only around 15 mph... I thought it was an exhaust rattle and it was. I replaced the whole exhaust with a flowmaster 80 series catback:banana:. No more rattle, until I slowed down I could hear a new grinding that was masked by the old rattle! :(
Anyone know what it could be? only makes the noise when slowing down usually when I'm approaching a stop light or turning into a driveway.In America's Hat!
1997 Camaro 30th 'vert... GT1 cam/C6 wheels/Flowmaster/HIDs/Viper 2 way alarm/Alpine audio mods up the wazoo
2005 Equinox LT... mostly stock daily/Thule snowsports roof system/sound + interior mods
Exhaust rubbing or maybe heat sheild above the CAT. Or the CAt itself rattlring since they are just rack welded together.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I'm hoping its something as simple as a heat shield.
I'm praying it isn't a tranny or rear-end !
The car only has 55,000 miles on it so I can't imagine it's something that bigIn America's Hat!
Might need to grease the rear sway bar bushings also with the LCA's.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...1 week ago
I stopped driving...2 weeks ago -
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...3 weeks ago
