my 02 v6 bird doesnt have posi - FirebirdV6.com/CamaroV6.com Message Board
  • my 02 v6 bird doesnt have posi
    hey guys i was just wondering since u guys are the v6 experts if the v6's have a posi rear because ever since i bought my car ive notice only one tire spins out..I brought it to the shop and they said the rear is fine.. the car just doesnt have posi rear and to make the car posi it would cost alot.
    Re: my 02 v6 bird doesnt have posi
    what they told you was part true and part false. Yes, not all V6's came with posi-traction...as a matter of fact, reletively few did. However, it doesn't cost alot to install a posi...300 for labor, and however much you decide to pay for a posi
      300 labor
      100 gears
      120 posi
      50 install kit
      or just buy a whole rear end which already has 3.42 gears and posi installed, you just bolt it on yourself
        How hard is it to do that yourself? Also, what would be the benefits to it?
          I wouldn't attempt it on your own
          http://auto.howstuffworks.com/differential6.htm
            I would reconmend ripping a rear end off a parting out z28 or TA or something. Pretty sure they are all 3.42 with LS. I got mine from a wrecked z fairly inexpensive.
              Wrong, some have 2.73s
                before you buy all the stuff for posi check your build codes on the inside driver door you will be shocked to find out whats there. the code for posi is G80 and GU6 thats for 3.42 gears which TheGr8Schlotzky informed me.
                just double check before u spend the bucks
                  Not trying to thread hijack, but do you know the code for if it's a 3.73 gear?
                    there isn't one; no F-body left the factory with 3.73 ratio gears
                      Oh. heh heh heh. Well then....I am now slightly less stupid.
                      Thanks
                        Were those the rear ends they put in the automatics? or just an option from factory?
                          yes my camaro is an automatic and has a 3.42 gear stock
                            3.42 gear and posi is a performance option
                              Originally posted by slow6
                              300 labor
                              100 gears
                              120 posi
                              50 install kit
                              Actually its a little more than that. You should give the average price not the rock bottom price. A rearend swap is 5 hours and most shops start at 80$ an hour these days. So that 400 labor. The gear is about right but that LSD is gonna run you atleast 275 and the cheapst i have ever seen an install kit was $70. Thats all new prices. I dont know used prices only cheapscates and breaders put used mechanical parts in their car.
