I just recently bought a 96 camaro, 3.8L. with an automatic trans. It seems like when Im cruising, especially on the freeway, its shifting back and forth into overdrive, even though my speed stays the same. Is this normal, Or is it a engine or trans problem?
Auto Trans O/D seems like it goes in & out
Re: Auto Trans O/D seems like it goes in & out
prolly a trans problem. I'd get it checked out sooner than later. My tranny just dumped eariler today.99 WS6
Originally posted by camaroextratears are great lube, but its hard to get a girl to cry onto her own ***.
torque convertor clutch, tcc. have your fluid checked. I had a 92/93 bonnie where teh speed would stay the same, but the rpm's would go up & down. turned out that some coolant had leaked from the plastic radiator into teh tranny fluid & the tcc had some rust on it & the clutch discs were deteriorating.1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
Flush and fill your tranny and also change the filter. If that doesn't do the trick, then your torq. converter is possibly going out and you need to think aboui changing it.
I changed the fluid and filter. there is a lot of air bubbles in the fluid now. and its still doing the same thing, even worse. it seems its shifting into O/D to soon, and boggs down. when i floor it, it seems to go through the gears ok until i let off. Ive heard something about a 2nd 4th gear bands go out on these trannys a lot.
Turns out, It was an engine problem. I had like 5 vacuum leaks, Fixed those, sea foamed the engine changed the temp sensor, I put some NGK V-fire plugs, and some delco wires on. It had one wire with a melted boot. Ran great for about 2 days. Now it has abad 02 sensor. Oh well 1 thing at a time.
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...3 days ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...5 days ago
