tranny leak - FirebirdV6.com/CamaroV6.com Message Board
tranny leak
  • tranny leak
    well i noticed that i have a leak and its tanny fulid. i have not go it on the left yet but what is the most common tranny leak on are cars i have 130k on a auto 3.4
    Re: tranny leak
    post after you look where the leak is coming from. It helps
    2000 3.8 A4 Pewter Camaro
      Re: tranny leak
      Probably just a bad gasket.
      01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
      AR stage 3 heads/intakes to be installed
      www.cardomain.com/id/firehawknwv
      www.vaperz.com
      PEWTER MAFIA/ Kristen's "PEWTER MAFIA KING"
        Re: tranny leak
        is it coming from the front of the tranny or where the ds connects? it's going to be a bad gasket. are you sure it's tranny fuild and your rear main seal didn't go?
        WAWA-A-HOLIC
          Re: tranny leak
          yes im + its tranny and it looks to be coming from the back of the tranny pan.
            Re: tranny leak
            than replace the tranny pan gasket if thats where it is coming from. Replace your filter while your there. DO NOT USE A CORK GASKET
              Re: tranny leak
              i mean its on the ground the spot of fulid it right under the back of the pan idk if thats is where it is coming from cant get it on the left tell next week
                Re: tranny leak
                wipe it all donw and see where it's deff comign from
                WAWA-A-HOLIC
