rear diffy fluid - FirebirdV6.com/CamaroV6.com Message Board
rear diffy fluid
  • rear diffy fluid
    so, i bought my car at 65k miles and now i'm at 112k. As far as i know, the guy never changed the diffy fluid, and i know i havent yet... i know the service interval on that fluid is like 90k. I have the y87 with 3.43's and limited slip...
    is diffy fluid like trans fluid in that if its past the service interval you gotta just leave it in or should i change that stuff asap? I just dont wanna be buying a new rear end anytime soon... which is the best route to go?
    2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
    Re: rear diffy fluid
    I think you meant 3.42 gears. Probably just a typo. No since its never been changed Id go ahead and change the fluied. Ive never heard that about tranny fluid that if its never been changed then to leave it alone. I think the grade of rearend oil to use in our cars is 75w30 or it might be the other way around. I cnat remember exactly. I use Royal purple gear oil in my car along with their engine oil. I will be using their tranny fluid soon as I install my vig stall. The stuff is expensive but I think its well worth it if you got the money for it.
    01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
    AR stage 3 heads/intakes to be installed
    www.cardomain.com/id/firehawknwv
    www.vaperz.com
    PEWTER MAFIA/ Kristen's "PEWTER MAFIA KING"
      Make sure your add the LSD additive too.
      Doug<br />1996 Camaro RS M5 Y87<br />SLP Bilstein shocks, Eibach springs, 1LE frt/rear sway bars
        75w90 is what i use by royal purple "max-gear" already has the limited slip additave in it
        2001 Camaro 3.8 A4
        1991 3000GT VR4
        2001 Mitsubishi Eclipse GS
          how many quarts does it take?
            I believe its 2 quarts.
            www.vaperz.com
              you will have to buy 2 but only use 1.75
              2001 Camaro 3.8 A4
              1991 3000GT VR4
                I have always used redline mtl and mt-90 in my cars. Was planning to use it in my maro this weekend, has anyone had any issues with it? I do not have the LSD, I have the middle gear ratio, 3.23?
                  https://www.amsoil.com/storefront/svg.aspx
                  https://www.amsoil.com/storefront/ada.aspx
                  Rear Axle (3.5 pints, 2 oz LSD additive)
                  I have a Zexel-Torsen LSD and use this.
                  Raven
                    Originally posted by FirebirdGT
                    Today i was getting my oil changed at MGM lube (i.e. like jiffy lube). The guy on the counter asked me that if i ever had my diff fluid changed. I said to him that no. so, he checked something and told me he will change my fluid. I was concerned if i need synthetic (since i have y87) but he said that I don't. Well, I feel that i lost some HP. I was reading your write up in the tech section
                    Originally posted by tech article
                    The old disc-type limited slip differential (Auburn)was replaced with a Zexel-Torsen torque sensing limited slip differential in 1999. The new differential requires the use of synthetic differential fluid because of its design. The slip-limiting uses metal-to-metal contact inside the case and thus requires the use of the more "slippery" synthetic lubricant.
                    and realized that i don't need synthetic. Is this true?
                    Plan: I think he just replaced my diffy fluid with some cheap regular gear oil. so, i think i should change it. should i get this
                    http://www.royalpurple.com/prodsa/mgeara.html = 2 quart --- this saves me time because it's all in one
                    the one you referred, how do you mix it? it seems complicated. Let me know your thoughts. my car's in the sig.
                    09 Nissan 370Z MB M6 Sports Package
                    www.the370z.com
                      A synthetic is too slippery for an auburn. If you have an auburn you need some friction for the diff to lock. Hence, you put in the additive in your fluid.
                        so, you're suggesting that i should buy some NORMAL gear oil and add this
                        https://www.amsoil.com/storefront/ada.aspx to the oil. it seems like my car doesn't pull like it used to after the diff. fluid change.i am not doing something right. i dont' want to drive too much with this fluid in the diff
                        Is there any way i can put the synthetic stuff??? like https://www.amsoil.com/storefront/svg.aspx or http://www.royalpurple.com/prodsa/mgeara.html
                        anyone else has any thought on this>>
                        www.the370z.com
                          You are absolutely right .
                          This from the auburn website:
                          -IMPORTANT LUBRICANT NOTE
                          The Auburn Gear limited-slip differential design has been extensively tested with high quality non-synthetic 80W90 hypoid oils treated with GM or Ford friction additives (3 oz. of additive will treat 1 quart of oil). To avoid differential clutch chatter (noise) and for optimum performance, use the oil and additive described above. Use of other additive and oil types may cause differential clutch chatter.
                          GM Part Number: 1052358
                          Looks like i will be going to the chevy dealership tuesday morning. Atleast i know what i need now.
                          anyone know the diff. between hypoid and non hypoid oil? (just curious)
                          www.the370z.com
                            hypoid gear oil is designed for rear ends, it's because of the type of gear, straight cut gears can use non-hypoid oil, gears cut at an angle, like your trans and rear end gears need use a hypoid gear oil. This has to do with compression. Hypoid gear oil is designed to handle the greater pressure of the angle cut gears. all rear end oil will be hypoid.
                            Finally you shouldn't use those places to change gear oil or trans fluid as most of them use a pump to suck out the fluid. It's faster and less messy for them but you can't clean off the magnet on the inside of the cover which collects metal shavings.
                            -Brad
                            2000 V-Star Custom 1100
                            :rock:
                              :tup: good info..
                              yeah those people i think sucked the fluid out because when my mechanic opened today, it was all gunky on the round pan. My mechanic did a very good job, cleaned everything and put it back. I used to leak a tiny bit fluid before but now it should be good. but anyway, job well done and thanks for your response.
                              www.the370z.com
