So I was working on draining my transmission fluid and then putting in a new filter/seal today. I ran into the problem of the seal being EXTREMELY tight. I did get it off however, but how the hell do I put the new one in. It is so tight I have no idea how to get it in. Is there a tool or trick I do not know?
Transmission Filter Seal
Re: Transmission Filter Seal
They are very hard to get out sometimes. I left mine in when I serviced my tranny.
lubricate it with transjel if you have some, if not, use tranny fluid and gently tap it in with a socket and hammer. be gentle. :)
you get a socket that fits the seal and hammer it in.
I had the same problem and had to hammer the side of the seal to bend it in. I just used the socket and hammered the new one in. I think next time the old seal stays in.Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
if it was easy, anyone could do it for a living
Haha, I changed the tranny fluid in my car a few months ago and did a very messy job. I heard scratching the bore of the housing was a no-no. I basically gouged it. Then I hammered in my seal. So far so good, but my hopes aren't too high for my tranny.i\'m not an ambiturner.
I have done more GM trans filters and fluid changes than I can count. Last year I found using a Special pry bar worked the best!!! Heres the link for the one I chose.
http://www.harborfreight.com/cpi/cta...temnumber=7929
you have to be careful and not score the bore with that
Originally posted by quick97birdI have done more GM trans filters and fluid changes than I can count. Last year I found using a Special pry bar worked the best!!! Heres the link for the one I chose.
haven't tried em on a trans pan seal yet tho... still deciding whether I want to tackle it myself or have a shop do the whole thing when installing a sonnax kit
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...9 hours ago
