I have a 1996 3.8l v6 camaro auto im pretty sure the gears are 3.08(not 100%) And i seem to be a series ring gear 2. what would you guys suguest I put in gear wise? And would i need to up the Ring Gear to a series 3 or just order a series 2?
inquiry About Gears
Re: inquiry About Gears
I would actually recommend gettin an entire rear end out of a 99+ M6 V8 car without traction control (unless you somehow have TC on the V6). That combo will give you 3.42 gears and a torsen diff. What year car do you have though and do you have drums or disk for the rear brakes? There will be a bit more involved if you have drums but not too much. Anyway it's a lot cheaper to swap the whole rear end than to put in new gears and you get the added benefit of upgrading to a limited slip differential.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
If you don't know what kind of brakes you have this might not be a good time to upgrade the car. Get to know your car and learn how to do small things first. Remember, learn to walk before you swim.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
i have a 96 and all i did was buy the gears. wish i hadnt now, but i will upgrade later.
i still have my drums too.96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
I'm sorry I thought you meant you didn't know the difference. In that case do a search on how to swap in a rear disc setup into your car. As for the rear the whole thing can be had for around 275-350 usually.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
search locally at the junk yars first so you can save on shipping but if you can't find one TA Creations (I think that's their name) has them almost all the time.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...2 days ago
