Bad shaking at higher rpms - FirebirdV6.com/CamaroV6.com Message Board
  • Bad shaking at higher rpms
    i just got done with my auto to manual swap.
    The car drives pretty good untill i get to about 4k rpms, and then it sakes really really bad, anyone know where i should start?
    do you think the clutch or flywheel is out of alinment?
    Re: Bad shaking at higher rpms
    maybe the tranny mount?
      lets say your at 2k rpm in 3rd and you mash the gas does it do it
      did you go with a urithane trany mount
        no it will be fine, untill i get to about 4500 rpms then it starts shaking.
        I still have my old stock tranny mount, i guess ill see if i can get a new one and see if it fixes the problem. I hope the problem isnt in the clutch/flywheel cause i really dont want to pull the tranny again
          there is fluiud in the tranny?
            lol yeah there is, 3.4 quarts
