Basically I am confirming that I read tech database correctly. If I buy a 93-97 rearend out of a f-body and it has disc brakes then it will have LSD also. Correct?
The way I read it Y87 came with disc and LSD and V8's came with disc and LSD. Base v6's came with drum and open. Is this correct? Is there anything I need to look for or a way to inspect used rearend from a junkyard? Thanks
yes, 98 and newer fbodies all had 4 wheel discs. 96 and 97 fbodies with disc brakes also had LSD. (Y87) 93-95 all had drums, and non y87 96,97 had drums.
