need a few answers.. - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: need a few answers..
    fine you're right, he can go ahead and get 4.10s if he really wants, but do you need to get your pcm tuned? will the shift points be kinda screwed up if you go that high? cause i know depending on how much gas you're giving the car the pcm tells the trans what rpm/mph to shift at or am i wrong in thinking that too?
    • #17
      No your 3/4 right, after the gears have been changed in a car you SHOULD get to tuned ASAP> or buy an after market one that askes for your gears. but concidering he already has 3.42's in his car the 2 jump up will just decrease his gas and affect his speedo that much more w/o the tune. No real damaging side affects i know of.
      But if your going 4.10 bud your next best purchase would be to redo all your parts such as heads,rod, n stuff. but then ur almost ready for a cam! lol :D
      1998 Red T-top V6 Camaro
      - K&N Filter, Pacesetter Headders, MagnaFlow 2.5" Hi-Flo Cat, FlowMaster 80 Series, PowerDyne Supercharger@9Psi More 2 Come
      • #18
        you're gonna have to retune the computer regardless of what gears you go to...4.56 to 2.73, if the gears change, the car's computer needs to be changed as well
        • #19
          Why would you need to "redo" your heads?
          • #20
            X2....
            Daily: '02 Black Yukon Denali
            Toy: '06 Torrid Red GTO
            Gone: '07 Charcoal Yamaha R6
            Gone: Ex-wife, lol
            • #21
              i think maybe he just ment get new better flowing heads?
              • #22
                again, why? Stock heads have been proven to flow enough to go into the 13's NA, 12's with a power-adder.
                • #23
                  show me
                  • #24
                    Originally posted by tkoforpresident
                    show me
                    Is that info not available in the timeslips section under details? assuming ppl havent lied and included all info...
                    • #25
                      show me
                      http://www.fullthrottlev6.com/forums/member.php?u=993
                      http://www.fullthrottlev6.com/forums/member.php?u=397
                      http://www.fullthrottlev6.com/forums/member.php?u=31
                      http://www.fullthrottlev6.com/forums/member.php?u=175
                      http://www.fullthrottlev6.com/forums/member.php?u=239
                      http://forum.camarov6.com/member.php?u=7472
                      http://forum.camarov6.com/member.php?u=3142
                      ^All of these members are running 13s or faster with stock heads on their 3.8.
                      EDIT: even Shirl made her 11.7 run on stock heads
                      • #26
                        not saying youre wrong but do you have any numbers with anyone running after market heads?
                        im just courious
                        • #27
                          sweeeet, thanks guys.... i think imma go with 4.10's.... i have a guy to install em for 100 bucks but i need some well put-together gears for a 3.8 maro online... know any sites?? and also i kno i gotta get it tuned basically right after i get my gears installed, so you know the best tuner i should go with?? thanks again..
                          • #28
                            im just courious
                            http://www.fullthrottlev6.com/forums/member.php?u=18
                            ^this is only person who i know that has aftermarket heads and is running them right, and is running a 12.4
                            Originally posted by WhiTTyV6Maro
                            know any sites??
                            Jegs, Summitt, eBay...
                            HPTuners
                            • #29
                              Last time I checked SLP had em for pretty cheap
