1LE Mount Installed - NO SPACER REQUIRED - FirebirdV6.com/CamaroV6.com Message Board
  • 1LE Mount Installed - NO SPACER REQUIRED
    http://forum.camarov6.com/showthread...523#post741523
    It WORKED perfectly!! 1LE mount installed WITHOUT a spacer!
    The problem is that the V6 5-speed has a 1/2" drop in the mount cross-member. I replaced the V6 cross-member with a LT1 auto cross-member which is straight - no 1/2" drop.
    V6 Manual Cross-member (rear)
    V8 Auto Cross-member (front)
    1LE Installed
    NOTE: The 93-97 and 98+ cross-members are NOT interchangable. The body holes are different.
    Raven
    Re: 1LE Mount Installed - NO SPACER REQUIRED
    I call BS, JK . Would this also work for us guys running poly mounts if we switched over to a LT crossmember? Good work and yes please posts pics when you can. Steve
      Sweet.
      Does it also has the hole in the right spot, or did you still need to slot the crossmember?
      2001 Pewter Firebird Y87, M5
      Go Sabres!
        I'll post pictures later.
        ok i got a v6 auto, so would i still need a v8 auto cross-member? lol and lt is 93-97 right?
          i have a v6 5 spd and i used the 1le mount no problem. didnt use a different crossmember or spacer
            The tail end of your tranny is 1/2" too low then.
            Raven
              Yes, will work with ES mount as it is 1/2" too low also.
              Raven
                Originally posted by zlexiss
                Sweet.
                We did NOTHING, just bolted right in.
                Raven
                  does that matter? i havent noticed any difference
                    ......help...so am i off to the junk yard for that 95 formula cross member?
                      You can put a angle finder on your driveshaft to see if the angle is off. Should be be at zero.
                        Pinion angle - it doesn't have much to do with the ground.
                        Go Sabres!
                          interesting to see that the lt1 and v6 trans crossmembers are different. Never knew it went lower like that for our cars and not the v8s.
                          http://www.bowtiev6.com/
                            NOTE: The 93-97 and 98+ cross-members are NOT interchangable. The body holes are different. For the 98+ cars, I think that the LS1 auto cross-member SHOULD work.
                            now i have a 97 auto, and can't get undermind right now, is my cross-member got that pocket or straight? cause if i need a straight, there is a 94 formula lt1 auto i can get it from
                              Since the trans mount is the same, I can only assume that they are the same.
                              Raven
