What is the lowest speed at which your car will shift into 4th? I have reason to believe my speedo is off, and i'm trying to find out just how far off it is.
To anyone with 3.42s and A4..
Re: To anyone with 3.42s and A4..
lowest speed... thats a bad way to figure it out dude. shifts are based on engine load, not speed. if you're doing 45 up a 25* incline it probably wont shift to fourth b/c you need the extra torque from 3rd.
anyways, that said, it usually shifts at about 40-43 for me when i'm just feathering the throttle.2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
40-45 is when it would shift. its will always drop into 3rd whenever i go under 40Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
or you can fullthrottle it, and see what your car should be at when it shifts.
what size tires do you have?
with 275/40/17 tires, under WOT the car should shift 1-2 at 44 2-3 at 83
if you can rev to 6k rpms
On my speedometer...
3 > 4 at 45mph at very light or no throttle
4 > 3 at 42mph at very light throttle.2002 Camaro Coupe<br />Navy Blue, A4, Y87<br />Whisper Lid, Raised Air Box<br />SLP Bow-Tie Grill, HPP3
Originally posted by Meatyshellsor you can fullthrottle it, and see what your car should be at when it shifts.
After reading that I was thinking that's waayy off..then i read the 6k rpms and it all makes sense! hah.
