how do i get the line seperated without using the tool mentioned in the haynes manual
clutch line removal
clutch line removal
96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHRTags: None
Re: clutch line removal
where do i get one96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
neither auto zone or advance auto has this tool. I tried there yesterday and i called today.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
See if they have a clutch kit for your car, open the package and take the tool out, tell them youll bring it right back or something.
My clutch kit came with one, and when i the slave cylinder it came with one as well.
So you could buy the slave cylinder open it, take the tool and return it.*Matt
I just snapped the slave cylinder off. I have a new slavecylinder going in so screw it. Thanks guys96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
